Yacht welding repair question
Before sand blasting I need to repair some steel work on the frames. Do I disconect the negetive terminal from the battery before welding.
Rodney Acreman
yacht owner - Maroochydore, Queensland, Australia
That's the safest way. Sometimes you can get away without disconnecting the battery, other times repair/replacement of the electronics gets VERY expensive if you don't disconnect. Other tips:
1) Keep the Grounding clamp of the welder as close to the work area as practical.
2) If working near radios, RADARs or their antennas, remove the radios if you can; or at least disconnect their antennas.
3) If the pieces to be welded do not have a short (approx. 1 Ft.), solid electrical connection between them, then BOTH pieces should be connected to the welder Grounding clamp.
Tom Gallant
- Long Beach, California, USA
