How do I create a black patina on iron?
I have been working on an iron bench. I have just removed all of the red rust and now it is bright and silver. What chemicals or formulas should I use to give it a black patina?
Kate Rossiterhome artist - Carrollton, Texas, US
You can use 20 gm tannic acid ⇦ this on eBay or Amazon [affil links] /2o gm tartaric acid ⇦ this on eBay or Amazon [affil links] / 1 lit water solution. You can paint it on your object(or spray or immerse object in solution). Instead tartaric acid ⇦ this on eBay or Amazon [affil links] you can use phosphoric acid(15 gm). Wax, oil or lacquer finished object, Good luck!
