Mass Finishing Process for Bead Bracelet
We want to develop a mass finishing process for the beads with chain through. Is there any recommendation about the equipment and media at mass finishing step?
Jane S.
- Cumberland, RI, USA
If I understand your question correctly, you have jewelry that is hooked together and you want to finish it as a complete assembly? This can be done, but is not normally recommended. There are to many problems and this is slow due to the small volume that can be properly processed. In most cases, this is done like a drag finisher and not normally allowed to free tumble. Not enough info to give you proper direction.
tony kenton
AF Kenton
