Searching for coatings for art on aluminum plates
Hi,
I'm an artist doing a project with aluminum plates that have have an image on them. Essentially, I've taken a plate with a carbon layer and used a laser to etch an image into it (it's a process for offset presses called CTP). The resulting aluminum plate is the final art work that I'm producing. According to the company that makes the plate, the plates have a "hydrophilic layer covering the aluminum" that prevents oxidation.
I would like to put an additional finish on the plate to prevent scratching, discoloration etc. Any help or suggestions would be greatly appreciated. I have researched resins, powder coatings, and off the shelf coatings - what is best?
Thanks in advance!
Howard Pyle
Artist - Brooklyn, New York
I'm doing an outdoor art installation using 1/8 inch aluminum sheets that are painted with artist acrylic paint. I'm looking for a primer that's suitable with acrylic paint. Can you help?
James Woessner
- Sausalito, California, U.S.
