Heat-resistant paint for hot-water pipes
My apartment has hot water pipes running through it, and the landlord had painted it white. The problem is that the paint keeps cracking. Is there a heat-resistant white paint that I can use to repaint?
Thanks very much.
Tanya Humboldt
hobbyist - New York, New York
If these pipes is steel you can paint it by enamel painting it is heat resistance painting but you must paint it in an enamel shop.
Aly Gomaa
- Cairo, Egypt
