-----Shot blasting causes edge chipping
Our problem starts when we use shot blasting for polishing heat treated stainless material; we use nitriding process treatment for this stainless material. We alway encounter chipping from the edge, I would like to ask "Is there any other option we can use to polish the edges of the treated material with out encountering chipping?"
Paullyn Bernardometal machining - Binan, Laguna, Philippines
Have you considered some kind of edge guard, guide, or fixture? This may cause a slight shadow effect or non-uniform appearance, but you didn't indicate that as a problem
AF Kenton
Why don't try finer or softer media or even wet blasting.
Good luck
Khair Shishani
