Wet paint touch up that will compliment a white powder coat on steel
I need to touch up a white powder coated product that is made of stainless steel and tig welded to a forged and hardened metal, and also in the weld area there is an epoxy adhesive ⇦ on eBay or Amazon [affil link] that bonds a small hardened steel pad to the fixture. The entire area that needs touch up is only about 4 to 5 square inches max, but I need to clean the area, and complement the standard white powder coat paint with a compatible paint that will withstand weather (an outdoor device)and cover the welded area as well as cover the epoxy, and the other metals, and I want to apply the paint with a brush or sponge to do away with broadcast spraying with a touch up spray can (runs...overspray,) etc. Is there a wet paint maybe epoxy based in white that someone could recommend that might do the trick? thanks
Dale Barnes
electronics manufacturer - San Dimas, California, USA
