Child safety products require bonding of PP to ABS
Do you know the best method for bonding ABS to PP? The surface area of the two parts in approximately 1 inch in diameter.
Shaazia Stonehocker
Safety products for children - Conroe, Texas
Shaazia,
The person who could give you perhaps some helpful data is Trevor Crichton (a contributor to this site) as it involves, I believe, some type of treatment to the PP to make it receptive to being bonded.
Generally speaking, you can't adhere PP or Pe to anything with success.
Is is possible to make a mechanical bond? Why PP or why ABS? Can't the entire section be made of ABS?
freeman newton portrait
Freeman Newton [deceased]
