Thread 231/99
Hard chrome plating -- minimum thickness
What should be the process sequence of Hard Chrome plating to get 96 hours CASS test ? What should be minimum thickness of Chrome plating (or minimum total thickness of undercoat + Chrome deposit)should be given to get 96 hours CASS test ?
Anil Kumar Sharma- Mumbai, Maharashtra, India
publicly reply to Anil Kumar Sharma
Mr Sharma,
In my experience, there are a few different factors that will dictate the way you will go about this. Cost being one. Component size, another. Mechanical stress in use, another. Hard chrome is not very rust resistant in thicknesses less that 10 thou. An underlaying coating of plated nickel would help things, corrosion wise, at the expense of mechanical strength,which is at a premium anyway with hard chrome. I suggest you provide more specifics about this part, its function, expected working environment and life.
Mark Hunter- Newcastle, Australia
publicly reply to Mark Hunter
