-----Material identification
A very simple question, can some one please explain with regard to Stainless steel what the "M" of the formulae CF8M relates too?
Kind regard,
valves - Auckland, Penrose, New Zealand
It denotes the presence of molybdenum as a significant alloying element. The "M" doesn't specify a particular percentage, and the actual percentage varies from alloy to alloy (in CF8M it is 2.0 to 3.0 percent).
Bill Reynolds [deceased]
I am not sure about that particular code without researching, but I know in the ASTM code that the 'M' means that it was heat treated twice.
Jeremy Kuhn- Lancaster, Pennsylvania, USA
