Selective removal of Calcium from wastewater
Q. From our waste water we want to concentrate our zinc level by means of electrodialysis or reverse osmosis. We want to achieve a zinc concentration 80 times as high as the starting level. The problem is that there is too much Ca in our wastewater (240 mg/L) and it will precipitate as CaSO4. Does anyone know of a possibility to remove the calcium and not the zinc?
Koen Joris- Belgium
A. I'll offer 2 suggestions:
1) If the source of the Ca is hard water used for rinsing, switch to using de-ionized water for your zinc drag-out rinse, or
2) Use a heavy metal selective (chelating) ion exchange resin to extract the Zn but not the Ca.
- Goleta, California
Q. CaSO4 precipitated in outlet of pipe and we could not pass rinse water to our ETP plant because pipeline choked. Give me advice for that?
yogini kalambhe- Nagpur, Maharashtra, India
December 16, 2016
