Stainless steel vs. aluminized steel for heat exchangers
I am presently investigating high efficiency gas furnaces and would appreciate an answer to my question: Which material is better as the heat exchanger - aluminized steel or stainless steel?
Jack Holowatch
- Mississauga, Ontario, Canada
Depends on what parameter(s) you use for "better".
Aluminised steel has higher thermal conductivity than most stainless steels which might be "better" in a heat exchanger, but it also has lower corrosion resistance which might be "worse". Then there are dozens of different stainless steels which have different corrosion-resistance characteristics as well as different thermal conductivities.
Depending on actual temperatures and atmospheres, heat-resistance might be important. That could be heat-resistance as in resistance to surface scaling through oxidation, or heat-resistance as in resistance to degradation of mechanical properties through metallurgical phase changes.
Mechanical properties would also be relevant if you are looking at high gas velocities.
Bill Reynolds
Bill Reynolds [deceased]
