Plating with copper sulphate
I would like to copper plate some copper items which are solder together. In other words, I would like to hide the 60 - 40 tin - lead joints. My thought was to immerse the copper items in a solution of copper sulphate this on eBay or Amazon [affil links] and water or vinegar in bulk on eBay or Amazon [affil links] . The negative lead of the battery would be attached to the copper item to be plated and the positive lead attached to a piece of copper pipe. Is this overkill or am I just spinning my wheels?
Bill Maddux
- Ridgecrest, California, USA
It's probably under kill. There is much more to a quality plating job than just putting a leaded substrate into a jar of copper sulphate and connecting a battery. If you do a very thin application of copper (a few millionths of an inch), you may make the solder less obvious. But you won't be able to get a proper thickness of copper plating bright, nor adherent, without a lot more steps.
If you would take a look at the FAQ section there is a lot of good info there that will explain electroplating and whats involved. You have the basics correct. But as with anything...there is a little more involved to getting it done correctly.
Tom Haltmeyer
- Peoria, Arizona, USA
