Color Anodizing
Dear sir,
I want to know that if I am trying diecast aluminium containing .0003% of silicon in it and I am trying color anodising on it but some black spots are coming on it. So please help me out whether I can do it on it or not.
Sharad Kathuria- Faridabad (Haryana), India
Nobody believes that such an animal exists -- an aluminum diecast alloy with only 0.0003 % silicon! Yes, diecast aluminum is commonly anodized and dyed, although some alloys are more suitable than others, and the quality of the casting process matters. Anodize 'spots' on diecast are most commonly due to 1) porosity and 2) silicon grains, especially the coarse ones occurring in slowly solidified, hyper-eutectic alloys lacking grain refiner additives. Presuming that you have a typical, silicon-containing diecast alloy, be sure to use a nitric acid-fluoride etch rather than a caustic solution. After anodizing, use extra rinsing, perhaps even including a warm DI water dip, to flush out any acid prior to dyeing.
Ken Vlach [deceased]- Goleta, California
I want to color the aluminium alloy 2014/2024 with green dye? suggest dye & why absorption of dye is not occurring?
Ibrar Shahhobbyist - Rawalpindi, Punjab, Pakistan
What were your anodizing conditions. How thick is the anodized layer?
Anodizing conditions are ;
concentration of bath(sulfuric acid)=10%by volume
current density=12 asf
voltage =18 volts
temperature=25 c
thickness achieved = 8-12 microns
You can use dyes for cotton fabric (cheapest but not best), or try to find proprietary product.
The conditions sound good, and the anodizing thickness is probably sufficient. Are you heating the dye tank?
