Surfactant Analysis
Can someone suggest simple ways to analyze for the amount of nonionic and anionic surfactant in a zinc-nickel plating solution?
Terry Tomt
- Enumclaw, Washington
I would suggest checking the surface tension to measure the amount of surfactant found in your bath. A fairly quick and simple test which can yield great results.
Travis Brown
Lacks Industries, Plastic Plate Division - Grand Rapids, Michigan, USA
