Activating Alloy42
Is there a suitable chemicals to remove oxides layer of alloy42 oxides but not react with aluminium as a pretreatment of tin plating. Or is there a chemical to remove alloy42 oxidation layer and aluminum oxide during pretreatment of tin plating?
Yun Liu
citric acid on eBay or Amazon [affil link] has been used to activate alloy 42. (usually followed by a nickel strikeNickel strike solution would attack aluminum, therefor cannot be used. citric acid will attack aluminum very slowly and may be suitable. Worth a try. There are proprietary citric acid activators for alloy 42 containing a small amount of a antifungal material. Try citric acid at 860 g/L and a temperature of 49 °C.
don baudrand
Don Baudrand
(Don is co-author of "Plating on Plastics"
           and "Plating ABS Plastics" eBay or AbeBooks affil links])
