What is phosphating?
What is phosphating? I am completing a wastewater discharge permit for a Jobshop that paints metals and plastics. Prior to painting, the parts are dipped in a cleaning solution to remove oil and grease. This cleaning solution contains phosphates. Is this phosphating, or is phosphating a different coating procedure?
Robert Adams1998
Dear Bob, phosphating is the process of providing a conversion coating for iron bearing metals and/or etching/activating for non-ferrous metals. When the metal comes in contact with the phosphate solution, a chemical reaction takes place (also called pickling). The phosphate coating is deposited. The topcoat will now have a better substrate profile in which to adhere to. Remember that aluminum does not accept a conversion coat unless phosphate chrome is used. The aluminum will still receive an etch that will accept good adhesion.
![]() Bob Utech Benson, Minnesota |
![]() Ed. note: Bob is the author of: "High Performance powder Coating" on eBay or AbeBooks or Amazon [affil link] |
Dear Sir:
Many heavy duty cleaners contain phosphates as part of their makeup. You need to determine if the job shop is just degreasing the part or actually applying a phosphate coating.
Phosphate cleaners are typically alkaline, phosphate conversion coatings are typically acidic.
Finally, it is possible to apply a phosphate conversion coating (zinc or iron) to aluminum.
Edward Koneczny- Birmingham, Michigan
please tell me in detail about accelerators used during phosphating as a paint base; also tell me about the post treatments regarding the phosphating process.
abhijeet.p.bapat1999
I am a chemist from Pakistan. I need some know how about metal pre-treatment system. Is there any gentleman who gives me information about alkaline cleaners, pickling solutions, phosphating chemicals. God bless you.
syed Iqbal Saleem- Pakistan
Hello, Mr. Bapat. Hello, Mr. Saleem,
There are entire shelves and even aisles in technical libraries which attempt to answer your questions, so it is hard to recommend just a single book, but Samuel Spring's Preparation of Metal for Painting ⇦[this on Amazon affil links] is a book that I can recommend.; or try "Phosphating of Metals" ⇦[this on Amazon or AbeBooks affil links] by Rausch. or "Phosphating & Metal Pretreatment" ⇦[this on Amazon or AbeBooks affil links] by Freeman. Good luck.
What is the difference between phosphate cleaner and phosphate conversion?
harish mehraemployee - delhi, India
September 22, 2011
September 22, 2011
Hi, Harish. Phosphates, such as trisodium phosphate ⇦ on eBay or Amazon [affil link] , are sometimes used as detergents to assist cleaning. But phosphate conversion coating, sometimes called phosphatization, is a pretreatment process for metal which improves its corrosion resistance and provides a good base for the adhesion of paints or absorption of oils. If you can provide some context rather than an abstract question, we can probably assist in more detail. Thanks.
