Trouble shooting on tin plating
Why do blisters occur when tin plating is done with aluminium based metal? What is the process for tin plating on aluminium? To do tin plating on aluminium casting can sand-blasting be done and then copper plating?
P.G. ChandramaniBharat Electronics - Bangalore, Karnataka, India
Zincate, strip in nitrip acid, zincate again, cyanide copper strike, bright acid copper plate.
1.if there is roughness in acid copper plating what the troubleshooting has to be done
2. if there is pitting in acid copper plating what the troubleshooting has to be done
- Mumbai, India
