Indicators for corrosions site in hard chrome plating deposit
I recently witnessed a test used on a Hard Chrome deposit, where a clear solution was dabbed onto the deposit. The deposit was approx. 1 mil thick. If pores or potential corrosion sites existed, the solution indicated this by turning red at the site. It sounds similar to the ferroxyl test, but red not blue. Could the solution contain phenolphthalein ⇦ on eBay & Amazon [affil link] ? I asked, but of course got no answer from the tester. I would like to make some of this solution for my own use, and I'm sure others would as well. Can anyone help?
Steve Delaney
- Beamsville, Ontario, Canada
Sounds a lot like a copper sulphate ⇦ on eBay or Amazon [affil link] test, but that should have been a light blue solution.
I assume that the basis metal is steel. The solution could be sodium or potassium thiocyanate ⇦ on eBay or Amazon [affil link] . This will react with corrosion products of iron (compounds in the ferric state) to give a deep red color.
dave wichern
Dave Wichern
