-----How do you apply galvanneal
I am making a marine trap that spends most of its time on the ocean floor. I've tried both zinc plating and a hot dip galvanize to the wire before applying a PVC coating in a fluidized bed process. I am having a problem with the PVC coating adhering. Someone has suggested galvanneal. What is this and how is it applied.
TOM ROBIDEAU- NORTHBROOKFIELD, Massachusetts
Galvannealing is essentially hot dip galvanizing followed by an annealing process that causes the zinc and iron to form intermetallics that are a good paint base. It seems that it should be easier to PVC coat than a galvanized finish. But isn't a primer required before the PVC coating?
