Cleaning brass hinges
I have brass hinges and handles in my kitchen and I would like to know a fast and effective way to clean them so that they will shine? My house is pretty old and I am currently trying to remodel and restore what I can of it. These kitchen cabinets are the origianl ones. Thank you very much
Kerry Bryant
- Calera, Oklahoma
To do the job proper, all hardware should be removed, unless you are talking about a light discoloration and/or oxidation. Even though you say this is brass, it is surprising what is really plated. For light work and plated materials, I would suggest ( if you have equipment) putting them in a small vibratory machine with dry polishing media. This might be done in a chemically, but someone else can answer that better.
tony kenton
AF Kenton
Place your hardware into a crockpot with a little laundry detergent and 'cook' them overnight. The paint will nearly slide off the next morning. Be careful and use tongs. Only remove one piece at a time, as the paint will re-dry very quickly. Good luck!
Neil McGee
self - Mission Viejo, California, USA
November 28, 2008
