Anti-seize
Dear Sir:
My question pertains to basics of anti-seize. We have been using graphite based antiseize for a while in tightening nuts and bolts in our die-shop, but a suggestion was based to go to copper or nickel based anti-seize ⇦ this on eBay or Amazon [affil links] . My question is on what principle does copper or nickel based anti-seize work and what are their benefits over graphite.
P. Shah- Rockford, Illinois, USA
I'm not especially familiar with either of them, but if the job can afford it, silver plating is the "classic" anti-seize. It's better than graphite for at least two reasons: first, it's permanent, it doesn't rub off; second, there are some environments where graphite is a no-no because of the loose "particles" in the atmosphere and the possibility of contamination or electrical shorts they can cause.
