Pyrophosphate zinc plating
Scenario: using soluble Zn anode with pyrophosphate electrolyte in solution, ph=about 12 and temp of 125 °F to plate out Zn coating.
Is there a cheaper electrolyte that will do the same thing without adding volume to the existing solution?
christy
Hello, Christy.
Unfortunately, I'm not sure I understand the question. You are trying to zinc electroplate from a pyrophosphate solution rather than a conventional acid zinc, alkaline zinc, or cyanide zinc? Why?
hello: I just want to ask about plating with acid; that the sodium cyanide is too expensive
thank you
yours
Ahmed el.nesr
- el.nesr plating
