How to gel Nitric - Hydrofluoric Acid
I'm looking for a chemical compound that allows gellifying a mixture of concentrated nitric and fluorhidric acids
Miguel Flesia- Argentina
1996
I want gelling agent for nitric acid and hydrofluoric acid mixture.
Ali inan- Bursa, Turkey
It's none of my business, but, like napalm, this stuff might not be usable except under VERY controlled conditions. What will inevitably happen is that someone will start sloshing this mixture onto vertical surfaces without the proper safety precautions, and someone, usually a bystander, will get injured.
Also, hydrofluoric acid is absorbed through the skin (and from under finger nails), the fluoride reacts with calcium in your bones... it's not a pretty scenario; find another way.
By the way, napalm gets its name from NAphthene PALMitate, a mixture of aluminum soaps used in jelling gasoline.
Hi, folks. This subject is discussed, and the answer provided, in
letter 32993. Good luck.
June 20, 2009
