Nickel-plating tear-off on zamak diecasted parts
We have recently launched a new product based on a zamak diecasted frame. The finish needs to be nickel plated. The first pieces came out with nickel plating tearing off (60% failure rate).
We redesigned the die in order to achieve better material flow and eliminate porous surface, but the problem remains.
Could anybody help?
Stefanos Anagnostou- Athens, Greece
Have you tried putting down a layer of other plating before nickel to seal the surface?
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
