How to fix scratched anodizing on architectural aluminum?
We manage nearly 60 commercial properties that have bronze (dark brown) anodized aluminum door systems. Years of use have given them a variety of scratches down to bare aluminum. Short of taking the doors off, removing glass and reanodizing or painting is there a product or process to spot treat the scratches on site to approximate the duranodic brown cololr? Would a metal blackening work? Is it available in a brown tone? The doors vary in age up to 25 years.
Jim Trudeau
Cummings Properties - Woburn, Massachusetts
If you are doing this with the owners appreciation of the situation, and you don't need to offer a warranty, you have a simple option:
If it were my own garage door, I would touch it up with a magic marker of a similar shade. In fact, touching up with a magic marker is a common factory process at anodizing facilities.
You may want to try chromate conversion coating. Perhaps if you will use concentrated solution for touch ups, you may get a color that's a near match. This solution could produce pale yellow to dark brown tint.
Dado Macapagal
- Toronto, Ont
