How can I eliminate this plating defect?
Hi:
I have some powder metal parts that have yellow chromate plating. Parts looked fine after plating, but after 2 or 3 weeks, white spots started to appear everywhere.
Following is the manufacturing process for those parts:
1- Molding iron powder.
2- Sintering.
3- Plastic impregnation.
4- Machining the ID.
5- Heat-treating.
6- Plastic impregnation.
7- Wheelabration.
8- Plating.
What is the root cause of those white spots and how can I eliminate it?
Afshin Afghan
Pacific Sintered Metals - Los Angeles, California, USA
Please can you tell me if the parts are:
1 Zinc plated
2 Plated from a cyanide or alkali bath
If the answer is yes to both the problem could be entrapment of plating solution in the pores of the parts.
The cure is to add a neutralisation step in using chromic acid solution
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
