High sulfur Nickel Strike
Q. Is high-sulfur nickel strike worth it? We are considering adding a high-sulfur nickel strike to our duplex nickel process. Based on information I have gathered, the strike is more cathodic to the semi and the bright and would be sacrificial. The millivolt potential difference between the bright and strike is supposed to be 15-30 millivolts. We also have a "dull" nickel in our plating line that currently performs the same way electrochemically.(approx. 30 millivolts cathodic to the bright).
The question I have is: Is there an additional advantage of the strike that would increase corrosion resistance over the dull nickel? Is the strike's only benefit it's electrochemical potential difference? Is there anyone out there who has done any experimentation in this area?
John J Bereza
- Grand Rapids, Michigan, USA
A. The third layer is supposed to improve corrosion protection. Review the literature for research performed on this subject. If the 3-layer system is called out on your specification, then it is worth it, for sure.
The AESF, I'm sure, has done some research on this.
tom & pooky   toms signature
A. The Tri Nickel system offers superior corrosion resistance to a duplex nickel system.
There is plenty of info in a ASTM spec called ASTM B456 which is a good starting point that will set to rest a lot of doubts you expressed.
It is entirely possible to achieve 44 to 48 CASS hours using a properly plated Tri Nickel layer followed by the required thickness of chrome. The Japanese Bikes are living examples.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
A. I do hope you are going to add the high sulfur between the sulfur free and bright layer as the intermediate layer? Aren't you talking about conventional Tri Nickel ?
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
Why does sulfur increase the electro-potential in bright nickel?
Q. Why does sulfur increase the electro-potential in bright nickel?
Nick Holmes
Employee - Stoke-on-trent, UK
November 22, 2018
