Letter 9060
Dissimilar Metals
My questions is concerning corrosion due to contact between two dissimalr metals. I have an extruded alum. tube 6063-T5 and some structural steel tubing. The alum. is painted with a 2-part polyurethane paint. What type of material should be placed between the two dissimilar materials to help prevent electrolytic corrosion? The alum is used as an architectural feature in a commerical building and the steel is needed for structural support.
Any advise would be greatly appreatated.
Rafael Rivero
- Corona, CA
This is a common problem in aerospace where cadmium is used. For commerical work I would suggest galvanising which would also give good corrosion protection.
Martin Trigg
surface treatment shop - Stroud, Glos, England
Dear Reader, please --
Post a question on a different subject.
