Replating brass pulls for
furniture
I just had an antique dining room suite refinished. The
pulls I think are stamped tin. A magnet will stick to them.
The brass finish had worn off. What is the best way to
replate the brass?
Bill Yates
- Houston, Texas
A consumer can't do brass plating, Bill. Besides being
quite complex, it can only be plated out of cyanide
solutions -- and cyanide is the last thing you'd want around
a house. You would need to send the parts to a plating shop.
However, compare your picture to some antique brass
drawer pulls on e-bay. I would bet 5 to 1 that your picture
is showing brass (or "gold") paint, not brass plating. Try
to scrape some color off the back side; although brass
plating can wear thru, it won't chip off like paint.
finishing.com Inc. - Brick,
NJ
