Removing stains from bath tubs
< Prev. page (You're on the last page of the thread)
Q. Hi. My daughter has poured neat disinfectant onto an old bath at her rental causing brown stains; the active ingredient is benzylalkonium chloride. Will hydrogen peroxide take it off do you think?
Susan Kane- Newcastle NSW Australia
February 16, 2013
Q. My acrylic/fiberglass (don't know which one) bathtub is next to a window (with the shade always closed). I had candles and flower candle rings around the top of the tub. I removed the candles/rings and those areas are white and the remainder of the tub has turned yellowish (not evenly). Would this situation be alleviated by the use of hydrogen peroxide to make my tub white again?
Linda Rhodes- Murrieta, California, USA
June 30, 2013
I've still not seen a response to my question. Will Ted respond to it?
Linda Rhodes [returning]- Murrieta, California, USA
July 16, 2013
A. Hi Linda. This is a public forum where we share camaraderie and post people's questions & answers. I have no experience in this area, so I only respond if nobody else replies, out of courtesy to you for posting here.
I claim no expertise in tubs, but my belief is that the top layer of resin or coating on the tub has yellowed with time and/or with this minimal exposure to sunlight. I strongly doubt that peroxide will accomplish anything ... Sorry to transmit bad news.
July 16, 2013
Q. HELP , I have used drops of essential oils in my acrylic bath when bathing my granddaughter, and I have just rinsed the bath with water to clean it. As it is our second bathroom it isn't used very often and I have just looked at it and the oils have dried in a yellow staining on the bath sides. Obviously as the water has drained, the oil has stuck to the surface; you can feel it is raised so isn't so much of staining but actual dried residue. Any ideas how to soften it to remove it any ideas welcome :)
- Perth Western Australia
September 14, 2013
Q. I spilt iodine
[affil links] on what I believe is acrylic plastic? I made the mistake of trying to remove it with ammonia
[on
Amazon (adv.)] which set it rather than remove it ... Is there any way to remove it? Or is all lost .... :( ?
Many thanks,
Lindy.
- Bedford, Massachusetts
January 7, 2014
Q. Hi this looks really promising, better than spending £400 to have it re-enameled. What strength hydrogen peroxide should I buy. Thanks
Jill B [last name deleted for privacy by Editor]- UNITED KINGDOM
June 21, 2014
June 2014
A. Hi Jill. I see no advantage in using an overly strong and unnecessarily dangerous concentration. I'd just go with the 3% drugstore strength. .
Q. Since taking up residence here three years ago, I have been battling the rust (?) brown stains/film on both tubs and surrounds, but the same "blight" is in the commodes, inside the refrigerator by the lights, pieces and parts of almost every electrical outlet, lightbulbs (including fluorescents), sockets, with few exceptions, almost anything electrical. STRANGELY, where water sits in the back of the tank, no stain, but when I siphoned it out for cleaning, it started to stain as well. I will work on the stains for hours, swapping out product, going back to baking soda & peroxide, sometimes Glass Stove cleaner, sometimes it works if I don't RUB, when I rub it's like I'm sealing it back into the finishes; and sometimes, I'll just be wiping it down dejectedly and there's an incredibly clean spot under part of my labor. What the?? Now I'm trying again, with a paintbrush and patience. I just don't get the chemical reaction that's doing all of this damage...any thoughts? This is the first community I've discovered who doesn't think rust is rust and nothing else happens :(
- Mandeville, Louisiana USA
July 1, 2014
OMG USE THE HYDROGEN PEROXIDE IT WORKS!! I Also USED A CHEMICAL FOR MY DRAIN AND IT STAINED LIKE CRAZY. SO I GOT ON GOOGLE READING PEOPLE'S COMMENTS AND TOOK THE ADVICE, AND IT TRULY WORKED. THANK YOU ALL..
L. johnson- Muskegon Michigan
July 16, 2014
Thanks for this helpful information. My kitchen sink was clogged and my husband used something that made our bathtub look stained. I tried several solutions, but the stains would not come off. Then I used Hydrogen Peroxide and the stains instantly disappeared.
Carla McClure- Hickman, Kentucky USA
July 19, 2014
!! Dennis -- write a book already! We're waiting on more wisdom!
Tj Ones- Fresco, Texas
I had ugly brown stains in my tub from removing mildew grout stains with bleach in a spray bottle. Just spray bleach on the mildew and within minutes the mildew dies leaving nice grout again. Unfortunately, the dead mildew dripped into the tub leaving ugly brown stains. Tried spraying on Hydrogen Peroxide and the brown stains simply disappeared -- incredible.
Charles Naftal- Mineola, New York USA
September 20, 2014
Sadly the hydrogen peroxide did not work for my drain opener stains. Don't know what to do...
Dani Lawson- Tinton Falls, Virginia
November 21, 2014
Hi. The peroxide answer was for porcelainized cast iron tubs, plus wherever else it may be useful.
It is possible that if your tub is fiberglass or acrylic, that the drain cleaner damaged it to where simply removing the rust won't restore its looks :-(
December 2014
I used a clog remover containing sodium hypochlorite and sodium hydroxide in a drain in a porcelain on cast iron 100-year old sink and discovered brown stains around the drain area - I very likley was not careful and let the product splash out. The advice to try hydrogen peroxide is fabulous - it started removing the stains immediately and I soaked a paper towel in the hydrogen peroxide and let it sit on the stained area for just a few minutes and now the stains are gone. Thank you SO much for the chemistry lesson!
Ardath Weaver- Raleigh, North Carolina, USA
December 10, 2014
Q. I have lived in our current house for 15 years. We have had the yellowish/brown stains in the old tub the whole time. I assumed it was the enamel wearing through. Now that I see what it is I had hope but none of the suggestions seem to be working for me.
All of the related stories indicate that they were able to fix a problem that they had caused ...soon after they caused it.
Has anyone been able to remove the chlorine tub stains after years and years?
thanks!
- Strasburg, Virginia-USA
December 19, 2014
A. Use Liquid Clorox 2 to remove the brown tub left behind from drain openers. It comes in the blue bottle. Make sure it is Clorox "2"
Works great. It's nice and thick, so it coats real nice. I promise this is the trick!
- Tulsa Oklahoma USA
December 20, 2014
Hallelujah to the people who posted about using simply peroxide on removing totally browned tub from using sulfuric acid in drain. I panicked when I saw enamel tub completely stained. Thank you thank you for this site and all of you folks sharing your experiences which saves time and much money. Just call me grateful.
Regina Williams- jacksonville florida usa
March 13, 2015
Q. I had my tub professionally refinished 6 years ago. The contractor used an acrylic epoxy applied with a[on eBay or Amazon (adv.)] . I have minor red rust hard water stains beginning to show and would like to stay on top of them before they get bad. I was going to try to use the peroxide but I am not sure if this will harm the painted surface. The contractor told me to only clean it with scrubbing bubbles but I think he just wanted to cover his butt. Normally I would use the works, but I am concerned that might damage the surface. Can anyone shed light on what to use without hurting the painted surface?
Jenny Tully- Cleveland, Ohio USA
March 23, 2015
The hydrogen peroxide worked like a charm on my bath tub. Thanks a million.
Linda Wright- Chicago Illinois USA
June 3, 2015
The hydrogen peroxide worked immediately. I will take the Clorox 2 back since H.P. is cheaper. Thank you sooooooooo much. I am so relieved.
Pat Reese- Quantico, Virginia
September 20, 2015
This is amazing! been battling stains on an enamel tub will try the hydrogen peroxide. Pool acid was used once but the stains came back! I am so happy to have found this conversation, surely saved me a light year of scrubbing!
Belle Bends- Harare Zimbabwe
October 3, 2015
My tub turned brown from a mixture of cleaning products. After reading some of the suggestions I tried the Hydrogen Peroxide and the brown streaks disappeared. Thanks so much for the helpful advice.
Gloria Harp- TOLEDO, OHIO
February 5, 2016
I used the Clorox cleanser on my porcelain tub. I left it for too long and the cleanser left lines of stains all over the tub. So frustrated 'cause I got no time to figure this out ... the HP works wonders, they are all gone; so glad I found this site instead of trying all kinds of methods.
Star Ferry- houston Texas
March 5, 2016
Used peroxide on my tub to remove acid stains, WOW! I put paper towels in the tub and soaked them with peroxide. I left it on overnight and the stains were gone!
Chris Novak- Euclid Ohio
April 17, 2016
!! Magic! Pure and simple magic! I needed a product to get the brown stains out of my porcelain tub after using drain cleaner. Hydrogen Peroxide worked like magic! We used just one little bottle that costs less than $2 and life is good again. Thanks to everyone who posted about the virtues of HP.
Adele Prince- Thomasville, North Carolina USA
September 29, 2016
Marvelous...It works so fast and so easy: Thank You
Joan Leong- San Francisco, California USA
November 18, 2016
Thanks for the solution of hydrogen peroxide! I was starting to worry after trying to scrub the tub and nothing worked. Thanks for the information!
Amy Morrison- Charlotte North Carolina
February 4, 2017
Q. Hi, used sulfuric acid industrial strength to unblock my drain unfortunately it has stained my off white bath tub white.
Is there anything that will work to get these white stains back to the baths original off white colour?
- London, England
July 26, 2017
July 2017
Hi Mark. Your tub could be fiberglass, acrylic, enameled steel, porcelain, or maybe another material. I don't think anyone could do more than guess even if they knew what your tub was made of. Letting peroxide sit on it for a couple of hours, then scrubbing with something like Barkeepers Friend [on eBay or Amazon (adv.)] is about all you can try; and still, while it might be "white stains", unfortunately it might also be that the acid bleached the color away permanently.
Q. Thank you for your response. I was using one shot to unblock the drainage hole, but unfortunately spilt it in the bath. My bath is a plastic type material. Would the method you suggested be suitable for the material of my bath or have you got another suggestion for this material to get the colour back to its original off white colour?
Mark kravetz [returning]- London, England
July 26, 2017
A. Hi again. Acrylic is not resistant to concentrated sulfuric acid, so I suspect that the color has been bleached away. You could try a rubbing compound [on eBay or Amazon (adv.)] on a buffing pad in a battery powered drill, but I don't know whether it will help or not.
August 2017
Q. I poured this orange liquid called biodrain down my tub. Now my tub is stained orange. I've tried everything to clean it. Any suggestions on what I can try to remove it?
Adina Steinberg- Inwood New York USA
October 15, 2017
October 2017
Hi Adina. Sadly, two reviewers on Amazon reported the same problem :-(
Please tell us what your tub is made of (to the extent that you know). I'm sure "I've tried everything" was merely rhetorical; but tell what you've actually tried so people can suggest something else -- a reader would look pretty foolish to suggest something, only to have you say "Of course I tried that! Didn't I just finish telling you I tried everything." :-)
A pic would help ... presumably it's not the whole tub but a small ring around the drain? Thanks ... and good luck.
! :-) Just want to chime in with all the other responders who used hydrogen peroxide to clean the brown stains left in their tub after using an acid based drain cleaner. Wow!! It was amazing! Took a paint brush suggested by someone else and simply wiped away the stains. No effort at all. So glad I found this site. We were ready to have the tub resurfaced which would have cost us a ton more than a bottle of hydrogen peroxide. Nothing else we had tried had worked. So thank you, thank you, thank you.
Rose Bowden- Azle, Texas USA
November 30, 2017
Cast Iron Tub Smells and Stains for No Traceable Reason
Q. Hello, I have a mystery. We had 2 old claw foot tubs and I used the upstairs tub every day for 10 years, cleaned it faithfully and gently. One day I smelled an odor like rotting onions around the tub. The smell rapidly worsened and with it came a brown stain. The stain deepened to the high water point of the tub and the stink worsened.
I tried various cleaners on the stain, dumped massive quantities of baking soda and gallons of vinegar [in bulk on eBay or Amazon (adv.)] down the drain. All other plumbing in the house was fine. 3 plumbers later nobody knew what was going on. I could scrub the stains away with Ajax [on eBay or Amazon (adv.)], but they came back with the smell within 24 hours. If I thoroughly dried the tub it still came back. Finally we had the tub removed, wrote it off to some unexplained fluke, figured maybe something broke down the enamel and reacted with the steel?
While awaiting the fix; and then the new, acrylic replacement tub, I used the other tub in the house in the guest bath. I have been using it daily now for a month, and the odor has begun in that drain! I have used nothing stronger than Dawn dish detergent and Bon Ami to clean it. Why is this happening to the second tub and only after I started to use it? I have asked myself what changed, and here is one thing that changed a few months ago. We started a low-carb diet a la Dr. Perlmutter's Grain Brain recommendations and I jumped on board with the supplements too. I have been looking up obscure side effects of things like alpha lipoec acid, wondering if my body soaking in that tub is causing some reaction now that I am taking the supplements?
I am reading lots of posts about sulfuric acid down the drain doing damage, how about a person taking alpha lipoec acid and soaking in the tub. I have stopped taking the supplements and I am now dousing the drain with hydrogen peroxide. I really hope it works. Wendy
wendy t [last name deleted for privacy by Editor]- Potsdam, New York, USA
December 19, 2017
A. I had stained my heavy old-fashioned bath tub by pouring sulfuric acid down the drain to remove a clog; the fumes made dark brown stripes on the sides and bottom of the white enamel tub. I was searching on the internet for the solution and on one forum I stumbled upon the answer where this guy was talking about 100% oxalic acid stain remover, so I tried it, and it works perfectly, I managed to remove all the stains. Cheers!
Jessie Connor- Sydney, NSW, Australia
January 13, 2018
Q. I have a question: removed shower doors, hard water residue left; so I poured soda & vinegar. It removed some not all of the residue and also etched the sides of tub;(
How do I buff out the etching and remove the residue safely.
Rose Vasquez- Fresno, California
March 18, 2018
Thank you SO MUCH for this info. I thought I had destroyed my 1936 enameled cast iron sink after using Drano to unclog it. There were brown stains everywhere and I thought it was rust, and permanent damage. I almost cried! The peroxide worked in 30 seconds. THANK YOU!! Nowhere else on the web have I seen this tip.
Amy Smith- brooklyn, New York, USA
April 9, 2018
Q. I tried the hydrogen peroxide on my very old porcelain over cast iron tub. It created darker rust spots on the bottom of the tub, the same reaction I get if using comet.
Usually oxyclean removes those, but not this time. I'm at a loss as to what to try next. Comet cleans but brings more rust. Hydrogen peroxide didn't clean and brought out tiny rust stains.
Has anyone tried Barkeepers Friend ? It says it has oxalic acid in it and not sure what that will do.
The tub is about 90 years old and is original to the home. I want to clean it up as best I can, but not looking to invest in resurfacing. Anyone have any ideas?
- Rockville Centre, New York, USA
May 27, 2018
A. Hi Roselle. Hydrogen peroxide is very good at dissolving rust, and Comet and Barkeepers Friend abrasive cleaners can be good at removing rust. What might be different in your case is that the porcelain coating is by now so old and thin that it is porous; water, peroxide, bleach, etc., appear to be getting through and contacting the underlying cast iron, which naturally rusts when exposed to any of these.
If you don't want to invest in resurfacing, but the existing surface is not watertight and allows moisture to get to the underlying iron, you're going to have rust. Your only solution short of resurfacing is to try to somehow make the porcelain less porous. Wax has very limited power but is better than nothing. A paint which is very close in color might get sucked into those pores so that even after you scrub off most of the paint with your abrasive cleanser, you might be lucky enough to have blocked up those pores. Good luck.
May 2018
June 23, 2018
Q. My plumber used a very strong, industrial-grade solution to unclog the drain of my fiberglass bathtub. Now a large area around the drain is yellow-brown and also the texture has been altered. Can anything be done to clear it? Would hydrogen peroxide help?
Haris Achilleos- Limassol, Limassol, Cyprus
A. Hi Haris. Hydrogen peroxide may remove some of the rust coloration but, sorry, it will not repair the texture which has been damaged.
June 2018
Dennis M., Thank you so much. My wife discovered a little brown stain tried to clean it and it became worse. I saw your answer and applied the Hydrogen Peroxide and the stain disappeared; thanks a million.
Enuel Caraballo- Amsterdam, New York
August 6, 2018
Hi, this is Dennis M, who originally posted the Hydrogen Peroxide fix for Sulfuric Acid fume stains on bathtubs. I am so glad this tip has helped so many people fix their stain problem. I want to give credit to my wife, Debbie, who came in while I was scrubbing the tub I had ruined with acid fumes--and poured Hydrogen Peroxide on the stain--removing it instantly!! So glad so many people have benefited from this trick!
Dennis Mostyn(now in) Portland, Oregon
November 25, 2018
