Seeking Equipment for Platinum Aluminide Coating
I am looking for platinum plating equipment for completing platinum nickel aluminide coatings on turbine components.
Benoit Leroux
Rolls Royce Canada - Montreal, Quebec, Canada
Process questions! Are you planning to platinum plate and then process in an oven or plate then flame spray or plate the dispersion in a process to your tribomet T104 or similar? Makes a great difference on recommendations.
Do you want to plate Platinum on the component and then aluminize to acquire Pt-Al coating? I suggest you plate platinum in manual way. It need not require any equipment except plating bath. Do you have well-developed plating directions? I know something about plating platinum! MengjinLi
Institute of Metal Research CSA - Shenyang Liaoning Province, China
