Need Bright Dip Mix
I have an anodizing business and would like to set up a bright dip tank. Is there a proprietary bright dip available? If not, I will get a bright dip mixed. Could anyone please give me the acids used and their mixing ratio?
Thank you - Kind Regards
Steve Power
Helipower Engineering Ltd - Nelson, New Zealand
Dear Steve,
Here the information for bright dipping processes on Aluminium.
There are several bright dipping processes for aluminium:
And the ratio ( the amount of nitric acid ) is hanging up from the companies processes.
If you decide to use nitric acid, be also careful with the ventilation.
FREDI YARCAN
- Istanbul, Turkey
YOU COULD TRY THE FOLLOWING BRIGHT DIP FOR ALUMINIUM:
ORTHO PHOSPHORIC ACID 87 % BY VOLUME
SULFURIC ACID 7% BY VOL
NITRIC ACID 6% BY VOL
THIS SOL WORKS FOR BOTH DIP AND ELECTROLYTIC PROCESS THE DIFF TEMP ARE REQUIRED THOUGH DIPPING TEMP SHOULD BE 85 - 90 °C ELECTROLYTIC PROCESS TEMP 45 DEG CENT CURRENT DENSITY 150 AMP/SQ FT VOLTAGE REQ WD BE ABT 20 VOLTS
VINEY CHADDHA
- DELHI, INDIA
