Media Blast or Chemical Pretreatment Better for Powder Coating?
I am looking to start up a small powder coating job shop. My question pertains to systems I have had quoted. Which pretreatment system has the broadest appeal and why? One system has a media blast system and the other has a chemical pretreatment system.
Tom Drake
- Charlotte, North Carolina
The answer to your question depends on a number of factors. However the main thing you will have to take into consideration is what kind of substrate you will be coating. If you are starting up a job shop and do not know this I would recommend the chemical pretreatment. A media blast system may be too aggressive for certain substrates and some systems can ingrain foreign objects (grease, oil) into the substrate rather than clean it. However there are a number of chemical pretreatments and you will have to look into the type of chemical treatment more carefully.
I'm sorry I could not give you a definite answer but I would require more information on your circumstances.
Drew Devlin
- North Lincolnshire
"Preparation of Metals for painting"
by Samuel Spring
"Phosphating of Metals"
by Werner Rausch
phos_rausch1991
or eBay or
I feel the pretreatment chemical wash is the best way to go. If you will be doing a lot of different parts the media blast could hurt certain surfaces.
Good Luck! Sincerely,
Cliff Shephard
Hi, Tom. Drew is right that we need to know what material you want to powder coat, but I think Cliff is right that chemical pretreatment is better because almost any metal you powder coat will require either a phosphate or a chromate conversion coating pretreatment for proper corrosion resistance. Good luck.
May 18, 2010
