Nitric Acid as Polishing Agent
Beside using phosphoric acid and sulfuric acid for chemical polishing, can I replace H3PO4 with nitric acid? If yes, what's the ratio between HNO3 and H2SO?
A.Rahman
- Selangor
We would need more information on what you are trying to do. What metal,what is required, what are you actually using?
Geoffrey Whitelaw
Geoffrey Whitelaw
- Port Melbourne, Australia
