To Clean PENNIES
WHAT DO YOU NEED TO CLEAN PENNIES?
KORTNEY JONES
- TILINE, Kentucky
Taco Bell hot sauce.
Dan Brewer
chemical process supplier - Gurnee, Illinois
There are probably a number of liquid systems that can probably achieve good results for you; however, as any gun reloader knows, the best method to achieve outstanding results is to use treated corncob in a small tumbler. Word of caution, if you use this method, pennies are plated and too long a time cycle will remove plating. Also be careful handling afterword. Use gloves or protect with thin oil film like WD-40 [on eBay or Amazon (adv.)] .
tony kenton
AF Kenton
