Seeking Sprayable Stainless Steel
Dear Sir,
I am looking for a stainless steel spray which when sprayed on any metal surface should give a finish like electroplating. More over the finish given by the spray should be abrasion resistance, and should not fall dull in long run.
Abbas.Vadnagerwal
TAMILNADU ENGINEERING & LUBRICANTS - Chennai,Tamilnadu, India
I have used high VOC coatings containing aluminum and a high temperature binder. These coatings are designed to withstand extremely high temperature, fairly rough abrasion, and still maintain a high "chrome" gloss. They are applied wet, then oven cured to develop the high temp and abrasion properties.
J. Mark Carlson
Polo Construction - Tulsa, Oklahoma
