Hard Chrome Plating on Aluminum
Hard Chromium Plating Handbook by Robert Guffie (1986)
avail from AbeBooks or Amazon
Hard chromium plating: A handbook of modern practice by Greenwood (1981)
avail from eBay or Amazon
Chromium plating by Weiner & Walmsley (1980)
Q. Chrome plating onto 7075 T6 ALUMINUM?
2.5 micron cyanide copper
20 micron copper
40 micron hard chrome
I want to plate it but the copper plate is rising like a bubble
I will be grateful if you help me.
operator - turkey
July 6, 2023
A. Hi Erkan,
I may be misunderstanding you, but you cannot plate cyanide copper (or pretty much anything else) directly onto aluminum. You must start with a zincate or stannate immersion coating (after cleaning, etching, and de-smutting).
Please search the site for "plating copper onto aluminum".
Q. I would like to know how to hard chrome plate aluminum or if you can?
Thank You.
Bruce Elbert- McPherson Kansas
A. DEAR BRUCE:
NOT AN EASY JOB BUT THEORETICALLY HARD CHROMIUM CAN BE DEPOSITED OVER ALUMINUM THAT IS FIRST ZINCATED (THERE ARE A NUMBER OF SOURCES OF INFORMATION ABOUT ZINCATING, ONE OF THEM IS THE FINISHING HANDBOOK).
THE QUESTION IS IF YOU REALLY NEED A HARD CHROME PLATE, REMEMBER THAT HARD CHROME HAS TO BE THICK TO BE WEAR EFFECTIVE (AT LEAST 0.5 MILS), OTHERWISE ITS FUNCTION IS MARGINAL. THEN THE PROBLEM IS THAT CHROME IS TOO BRITTLE AND THE ALUMINUM TOO SOFT. YOU WILL END UP WITH A PIECE OF GLASS OVER YOUR LIVING ROOM COUCH. CAN'T SIT ON IT.
ON THE OTHER HAND, IF THE REASON TO LOOK FOR CHROME IS TO REDUCE WEAR, OR CORROSION, THERE ARE BETTER APPROACHES SUCH AS ELECTROLESS NICKEL PLATING.
HOPE I GAVE SOME LIGHT.
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
or eBay or
Q. DEAR SIRS,
We are manufacturing aluminum cylinder block and pistons for small Two stroke I. C. engine, we want to know the whole process of aluminum hard chrome process.
himmat
- Pune, Maharashtra, India
October 19, 2012
A. Hi Himmat. No single book covers the whole process exhaustively, but Hard Chromium Plating
[suggestions on
& AbeBooks --> (adv.)]
by Guffie says aluminum is usually zinc or tin plated first, although castings are sometimes directly plated. Wernick, Pinner & Sheasby has a little over 3 pages on hard chrome plating of aluminum.
Hard chrome plating of aluminum is not a terribly common application because aluminum is so soft that you probably need a thick plating to exhibit hardness, and even then the item will be subject to easy eggshell cracking.
Q. Hi, I'm very very disappointed because no one can help me. Actually I make a line of aluminium of length 10 ft. I want to put hard chrome on it. Please tell me the procedures for how I anodize on aluminium lines and what is the procedure to do hard chrome plating on aluminium. I will be very thankful to you if you solve my problem.
Hafiz Waqasindividual - Lahore, Pakistan
May 1, 2013
A. Hi Hafiz. You may find our on-line articles "Introduction to Chrome Plating" and "Introduction to Anodizing" helpful if you are just starting out. Good luck with them.
After that, please spend a couple of paragraphs introducing yourself and your situation. People may be able to answer specific & limited questions for you, but the best known anodizing book is 1300 pages, so people would not know what answer of reasonable length they should give you vs. which 1299 pages they should skip if we don't know your situation :-)
You say that the aluminum is 10 foot long, but how wide is it? How thick is it? What alloy of aluminum is it? Why are you applying hard chrome plating to it? Do you know what thickness of plating you will need? Why are you anodizing these sheets? Do you know whether you want type 1, II, or III anoding? Thanks! Please hang in there and offer some details and we should be able to help! Good luck.
How to tell hard chrome from electroless nickel
Q. Someone has sent me aluminum rollers (tubes 35 mm dia and 280 mm long ) which are plated with something metallic. The measured hardness is ~ 1000 HV 0.1 and thickness about 45 microns. The plating is worn out and I am supposed to provide an alternate plating/coating. I suspect the existing plating is either hard chrome or electroless nickel or a combination of both. Is there a simple test to check this?
H.R. Prabhakara - ConsultantBangalore Plasmatek - Bangalore Karnataka India
August 28, 2013
A. Put one drop of hydrochloric acid on a clean area. If it turns green it is chrome. In another spot, put one drop of nitric acid on it and if it turns green, it is nickel. If nothing happens with either of these, the spot was not clean or it is neither chrome or nickel. James Watts- Navarre, Florida A. Dear Prabhakara, Vikram Dogra Irusha India - Chandigarh, India |
Q. Thanks James Watts! Your test says it is chrome. It reacts with HCl and not with HNO3. There is a small interesting complication. The component has both polished and matte finished portions. Reaction is fast on the polished portion as compared to matte finish. In fact, plating thickness is about five microns less in polished area. But reduced thickness is unlikely to increase reaction rate. It must be something related to polishing. Any explanation ?
Dear Vikram, plating is neither neither yellow nor blue. It is just metallic. With HCl it turns blue/green. Platers think it is chrome though they prefer testing it.
Next question is how to strip it without affecting the aluminum substrate.
A. Hi H.R.,
When Vikram said that chrome is blue and nickel is yellow, he didn't mean sky blue and canary yellow :-)
Rather, he was referring to a very faint cast to the silvery metallic color that "experienced platers" would probably recognize but others probably would not.
Please see thread 14252, "Chemical removal/stripping of chrome plating from aluminum parts". Stripping the chrome without affecting the aluminum will be a trick requiring a fair amount of skill, a little bit of luck, and favorable conditions of shape and thickness. Good luck.
Big Cracks in Hard Chrome Coating on Aluminum roller pipe
Currently, I am doing failure analysis on the hard chrome coating on the Al roller pipe.
There are three layer. Al substrate + Ni (50 µm) + Cr coating (100 µm).
It is exposed to 120 °C temperature. And, Cr coating hardness is about 850HV.
The crack damage is like the photos.
(Click the graphics for high resolution photos)
If anybody knows the reason and what to expect for the remaining life, please let me know.
Jingak Nam- Ulsan, South Korea
December 5, 2013
A. Hi Jingak. The first question is what do you mean by failure and remaining life? Are you considering those deep, full depth cracks as failures? And why exactly do they constitute failure ... corrosion, impressing a crack pattern on what they are rolling, flaking off?
I think three possible routes to those cracks are: 1). they were there from the beginning; 2). the much higher coefficient of expansion of aluminum caused the chrome layer to fail in tension; 3). 'eggshell' cracking developed because the underlying aluminum is too soft to support the load.
I am not a metallurgist and cannot claim any significant experience in evaluating such microphotographs for cause of failure, but it just looks like '2).' to me and, because chrome expands only less than half as much as steel whereas aluminum expands almost twice as much as steel, I would expect a significantly higher incidence of such failures on aluminum rollers than on steel rollers, and that 120 °C might be enough to do it.
Alternative to Hard Chrome Plating for Aluminum
Q. Currently we are doing Hard Chrome plating on QT [ed. note: Quenched & Tempered] Steel.
If Aluminum alloy is the alternate to QT Steel, then what would be the alternate for Hard Chrome Plating where all the required Hardness and strength parameters should achieve.
Project Lead - India
June 14, 2017
A. Hi Praneeth. Remember that it was you, not us, who claimed that aluminum alloy is a good alternate to QT steel :-)
Certainly aluminum can be hard chrome plated, electroless nickel plated, electroless nickel plated with occluded materials like tiny diamonds, electroless nickel plated with teflon additions, hard anodized, or anodized with teflon additives.
But any substitute of one material for another or one coating for another requires very careful evaluation -- there are no "drop in" substitutes. Please give us the full details of the component you are trying to build from aluminum. Hopefully it's not a hydraulic piston rod :-)
Q. Thank you Mr. Mooney
Yes, it was a hydraulic piston rod.
Currently we are using QT mild steel which was hard chrome plated.
We are trying to reduce the weight, and so preferring Aluminum alloy as the alternate material with similar approximate base material properties with less weight.
But coming to hard chrome plating for wear and hardness properties, what can be suitable for aluminum is my concern.
- Pune, MP, India
A. Hi again. I'd stick with the hard chrome plating then and hope for the best, as it has proven itself for decades as the ideal surface for hydraulic piston rods.
A. Electroless Nickel Low Phosphorus is a good alternative for hard chrome.
Eduardo LorońaPlating Tech. - San Diego, California
November 2, 2021
June 2017
A. Hi Eduardo. Thanks! I'd agree that electroless nickel can often be a good substitute for hard chrome. But do you have experience in using it on hydraulic piston rods? I'm heard that the cracks associated with hard chrome are important for holding oil on hydraulic piston rods ... but I'd be happy to be told I'm misinformed :-)
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
Q. I WANT THE PROCESS FOR HARD CHROME PLATING ON ALUMINUM TUBES.
KHAMESRA NS- MUMBAI INDIA
December 21, 2020
A. Hi Khamesra. Please introduce yourself and your situation to give us a starting point.
Guffie says "An interface of zinc or tin is almost always deposited on aluminum ... some cast aluminum alloys, however, are plated directly ..." and not much else. But see earlier postings above yours.
