Nickel Plating Brighteners: Everything to Know
May 22, 2021
I am trying to figure out what the last "brightener" ingredient is on this nickel plating solution video.
https://youtu.be/QjfNrZigqL0?t=725
I have all the components figured out but the last. He says some kind of naphthalene sulphonic acid but I can't understand and he's never responded to my question.
If you read this PDF ...
https://nickelinstitute.org/media/2323/nph_141015.pdf
. . . on the carriers section it saysCarriers --
Does anyone know what kind of naphthalene sulphonic acid he is using since there seems to be multiple kinds?
Nickel Plating Solution (Makes 250 ml)
250 ml Water
50 g Nickel sulphate
5 g Boric Acid
2 g Sodium Chloride (Table salt)
1/100 g Thiourea [on
Amazon (adv.)] (brightener)
1/10g ?-?-?-naphthalene sulphonic acid (brightener)
Thanks for any help!
- Baton Rouge, Louisiana
A. 2,7-naphthalene-disulfonic acid
(pubchem.ncbi.nlm.nih.gov/compound/Naphthalene-2_7-disulfonic-acid)
- Ridgewood, New Jersey
July 11, 2023
Q. I am looking for a directory or list of nickel brightener manufacturers in the US, specifically using PPS and/or PPS-OH in their formulations. Wonder if anybody could help me out in finding the above or give me any clue. Thanks.
Elena
- Italy
1996
A. Hi, Elena. That's a tough one because proprietary brighteners are a principal income source for most suppliers, and I think they will be reluctant to give much information about what components they use in making them. However, you might talk to the suppliers of nickel plating solutions that you can reach, and see what you find out.
Look under "Plating Processes, Nickel" in the "Products Finishing" Directory (ISSN-0032-9940/82), for a list of about 50 suppliers.
P.S. -- What exactly is PPS?
1996
Q. Ted,
Thank you so much for your help.
PPS is a chemical used in the manufacture of nickel brighteners (propanesultone). PPS-OH has the same application but being of different chemical nature (Hydroxysulfopropyl pyridinium betaine) is less hazardous. I'd need a further little help from you, how can I get to the Products Finishing Directory you mentioned? Is this something I can access to from Italy on the net or finishing.com? Thanks again.
Elena Lamperti- Italy
1996
A. The Products Finishing Directory is a handbook published annually by Gardner Publications. It is inexpensive, about $10 or so. A library or bookstore should be able to provide availability info from the ISSN number I gave you. You may find copies of old editions from on-line bookstores, or contact Gardner Publications through pfonline.com
1996
A. Try Enthone-Omi in Italy or anywhere else in Europe. They manufacture nickel brightener.
Sara Michaeli
Tel-Aviv-Yafo, Israel
1996
A. Hi Elena,
I have been watching this letter since it was first posted. I don't know what you do in Italy, but talking about brightener formulations openly in the USA is an absolute taboo. I mean, it took me years to say saccharin (gasp) in public (I still blush when I do that). I wasn't going to be the first, but since you told us what PPS is, I guess I could talk a little bit about nickel brighteners. There will probably be a cross-burning on my front pebbles tonight, but here goes:
I believe that propane sultone is a precursor in a pathway to the pyridinium compound you referred to in your last letter. But this has more to do with designing nickel brighteners than it does with formulating a practical nickel brightener. Many companies sell organics which function as Class I or Class II nickel brighteners and can be mixed right up in your sink. That's always been a fantasy for platers in these parts; buy the commodity chemicals for 1/100 the cost of buying proprietary additives from chemical houses.
I no longer work in formulating brighteners, do you sell organic chemicals? I'm still not sure what you can do with this information, not that it's any of my business.
Best Regards,
"Lookin' for a lover who won't blow my cover, she's so hard to find." -- The Eagles.
Wait 'til you see the ads in Metal Finishing magazine, Tom! There, right out in the open no less, a company called Seal Sands Chemicals is offering "A finer finish for nickel plating", PPS-OH-40% w/v. They go on to say this is 1-(2-Hydroxy-3-sulfopropyl)-pyridinium betaine, that it's pyridine-free, and that they also offer N-benzylniacin 24-26% w/v as well.
Want supplier of nickel brighteners
1996RFQ: We want to license or buy duplex nickel plating processes for decorative chrome plating
Bert SherwoodEd. note: Sorry, this RFQ is old & outdated, so contact info is no longer available. However, if you feel that something technical should be said in reply, please post it; no public commercial suggestions please ( huh? why?)
As you can see, Bert, we appended your inquiry to a thread wherein some organizations seem able to offer you such technology, and seem eager to do so. Good luck.
1996
Q. Hi guys, I'm looking for information about types of brighteners for use on the Ni and Ni-P electrolytic plating system, I heard from some friends there are some types that contain sulfur (but this can cause me adhesion problems), I'm looking more on brighteners without sulfur. If you can give me information on the most recommended ones including their characteristics or contact me with someone who supplies them I really appreciate it, thanks in advance for your help.
regards,
Luis Morenocaptive plater - Jalisco, Mexico
A. Sulfur-containing brighteners for nickel are the most common ones and they do not cause adhesion problems. Sulfur free systems are used mainly for corrosion reasons. You can find brighteners at any supply house for the metal finishing industry.Sara
Sara Michaeli
A. Luis:
Cobalt salts were very popular Ni brighteners in the old days, especially for barrel applications. I don't believe anyone sells them as brighteners anymore, but you can buy cobalt sulphate or chloride and use low concentrations (~.01 g/l, if memory serves) to get a brightening effect (not as strong as with organic ones). You need to experiment.
Sara is right, though, organic brighteners if used properly should not cause adhesion problems.
Good luck, Berl
"PlaterB" Berl Stein
NiCoForm, Inc.
Rochester, New York
A. Hi, folks. Although it's true that sulfur-bearing brighteners should not cause adhesion problems in normal circumstances, organic brighteners can cause blistering problems at very high temperatures. And I suppose you could call a blister an area of non-adhesion :-)
My understanding is that sulfamate nickel (no added brighteners) does not have this problem, and is a good high temperature solution.
Q. I know that it is possible to make in-house alkaline and acid cleaners for plating processes, but does anyone know how to make in-house brighteners, particularly for bright nickel plating?
Chris Ballew- Newport, Tennessee
A. Hi, Chris.
ASM's Metals Handbook Volume 5: Surface Engineering will tell you quite a bit about carriers, brighteners, and auxiliary brighteners in its Nickel Plating chapter.
We will be happy to print the names of any other published references anyone would like to contribute, but can't print actual formulations or technical data since this is the industry's most closely held trade secret and the anonymity of the internet could compromise them.
A. Dear Mr Ballew
The design and successful manufacture of Nickel Brighteners is a fairly long and tedious job taking up to a lifetime of experience to make a stable product that produces repeatable accurate results. You obviously wish to make your own Nickel brighteners for some undisclosed reasons.
However if you wish to assemble Nickel brighteners and have a requirement of, say, one to two thousand liters, it will be possible to help you with pre blended intermediates which are then mixed to produce a workable brightener system.
It is done by some very large plating shops that wish to economise on costs and control the quality material inputs themselves.
Kind Regards and Good luck.
Asif Nurie [deceased]
- New Delhi, India
Q. Dear sir:
Please explain about making nickel plating brighteners.
Shahin Pourazar- Tehran, Iran.
A. You can formulate the nickel brighteners and additives by blending the intermediates available. There are various combinations to formulate the brightener and the choice depends upon the application, i.e., for barrel or vat, high speed (quick leveling) or the further topcoat required (gold / chrome). There are companies who can supply such intermediates.
ANIL BASRANI- Mumbai, Maharastra, India
Professional help on nickel plating brighteners, please!
Q. Greetings,
About a month ago I started plating some motorcycle parts at home. I have a 20 gallon setup with all the necessary tanks. What I'm inquiring about is what chemicals act as brighteners and levelers in nickel baths, and in what quantity must I use them?
After polishing, my pieces look impeccable prior to the chrome bath, and have exceptional brilliance after the chromium plate. The only problem I need to resolve is what additives can I add to my nickel bath. Most pros I've discussed this with don't know what they are exactly. I'm using a non-cyanide Watts bath.
Any and all help is appreciated.
Frank Bruno- Toronto, Ontario, Canada
A. Hi, Frank. It is true that you can use such additives as saccharin as carrier, 1,4-butyne 2-diol as an auxiliary brightener, and Thiourea [on eBay or Amazon (adv.)] as primary brightener, with Johnson's baby shampoo as the anti-pit. Further info about these generic additives and the roles of the individual components is in the ASM Metals Handbook Volume 5. It's good reading.
But maybe you've already been offered professional advice but didn't want to hear it; professionals use proprietary products not because they are too dumb to mix their own additives, but because they are too smart to :-)
These generic additives represent returning to the 1940's. Research scientists for the major suppliers have spent their entire careers developing appropriate additives, and their employers have paid their wages for all those years, and they are recouping that investment by selling these proprietary additives by the gallon. That's why no one will say exactly what they are.
But it's not so that you don't learn the info, because you probably would not be able to put it to use anyway. Making brighteners isn't about mixing, it's about synthesizing organic materials from their precursors, like synthesizing plastics from crude oil. It's secret so their major competitors who can afford synthesis laboratories don't compete against them.
You need to either hand polish the nickel as you are doing (and which was done in the old days) or to buy proprietary processes that enable self-leveling. Good luck!
Formaldehyde as nickel brightener
Q. Hello... Is FORMALDEHYDE harmful for bright nickel baths? Can we use it for brightener?
Ahmet kalengineer - Istanbul, Besiktas, Turkey
A. Formaldehyde is not harmful for nickel plating solutions yet it cannot be used as a brightener.
Sara Michaeli
A. Hi, cousin Ahmet. ASM Handbook Vol. 5 has an excellent chapter on nickel plating and the role of the various generic brighteners and addition agents including formaldehyde.
Q. What is/are the product/s between [name of chemical omitted by editor] and [name of chemical omitted by editor] ?
Mohammad AbediPlating shop employee - Tehran, Iran
November 18, 2008
A. Hi, Shahin. Hello Mohammad.
While there is certainly nothing wrong with your asking, you will need to ask known associates or to inquire in the published literature. The formulation of nickel brighteners has been the electroplating industry's most tightly held trade secret for many decades. The relative anonymity of the internet is at odds with the protection of trade secrets because there is no practical way for us to know the posters, their vested interests, whether names have been spoofed, etc. A disgruntled employee could deliberately leak his employer's trade secrets under an alias to put him out of business for spite.
Again if anyone wants to reference published literature on the subject, we're happy to include the name of the original literature source on this page! But printing hints from essentially anonymous party A, augmented by information filled in by anonymous party B, and procedures from party C, can be tantamount to group sourcing industrial espionage :-) Thank you for your understanding of why we can't post such dialogs.
November 18, 2008
March 14, 2013
A. One place that I've been using for some good basic knowledge for awhile is http://www.substech.com/
They have several very informative articles on electroplating and some basic information on the common non-proprietary brighteners used.
There are several book samples available through Google books that also list the common chemical brighteners and concentrations they are commonly used in:
http://books.google.com/books?id=U6RPpeVFmjYC&printsec=frontcover&num=100#v=onepage&q&f=false
I can provide further information and literature that is publicly available.
Neither of these are strict 'how-to' guides, but they will put you on the right track.
- Boone, North Carolina
March 14, 2013
Thanks, Mark. Dennis & Such's Nickel and Chromium Plating [on on Amazon (adv.)] is the book extracted in the google link you offered, and it is indeed a great source of generic info on nickel plating additives!
A. As an additional note you can usually get away with using a sodium based salt of the acid in place of the acid itself. So if in your reading you come across Benzene Sulphonic Acid, you can use sodium benzenesulfonate or nickel benzenesulfonate in a pinch. This is an EXAMPLE, not an answer. Your answer is going to depend on the specific setup you have, there are no quick or general answers.
You've GOT to know your chemistry if you want good results from any plating. I do this as a hobby and I've learned WAY more than I ever expected. If you aren't willing to spend days and weeks doing the reading and research, or you just want a quick simple setup without learning the ins and outs you can get a hobby plating kit that will produce reasonable results for pretty cheap.
Knowing the ins and outs of the system and what is happening is why the guys here that share their knowledge are so impressive to me and why I read so much.
SCIENCE!
- Boone, North Carolina, USA
March 16, 2013
Sulfur brightener in nickel causing pits in titanium nitride topcoat?
Q. We are doing titanium nitride & flash gold PVD coating on nickel plated brass and zinc parts. We are observing some sort of pitting corrosion on the components. Could you please suggest a brightener for nickel plating without sulfur?
Mani Bhat- Bangalore, Karnataka, India
January 26, 2014
A. Hello Mani,
Acetylenic compounds for semi bright solutions are in wide use now. I am not a chemist so I can't give you formulations. Your best bet is to contact your Nickel bath supplier, and tell them what you need. They may have a brightener system that can be "slide converted" into your bath. Good Luck!
Process Engineer - Malone, New York, USA
January 27, 2014
Q. Dear Sara,
Thanks for your input. sulfur containing brighteners are widely used as nickel brighteners. I would like to know if sulfur free organic brightener can provide good grain refining and brightness so that corrosion can be reduced a little.
Your views please.
- Bangalore, India
January 29, 2014
A. Mani,
Sarah's response was to a question Luis had. Anyway, her advice and mine to contact your Nickel bath supplier would be your best bet.
January 29, 2014
Sulfur-free nickel plating brighteners
March 26, 2014Q. We do nickel plating with sulfur containing brighteners. For trials we need a sulfur free brightener. Please give some inputs.
Ramasubbu Sanakra bhatter- Bangalore, India
A. Dear Mr. Bhattar,
All bright Nickel plating additives are sulfur-containing. The brightness/luster is because of sulfur inclusion in deposit.
"sulfur Free" Nickel deposit is semi-bright in its appearance and almost No sulfur. Due to this such deposit is passive and nobler than bright deposit. sulfur free deposit forms a base coat in multi-Layered Nickel deposit, exhibiting higher corrosion resistance.
As far as I understand, commercially there is no such thing as sulfur free bright Nickel.
- Mumbai, India
May 18, 2014
Tell me how to formulate brighteners, levelers, and additives
Q. Hello sir,
I want to start my own chemicals business. So will you please tell me how to make or formulate plating chemicals like brighteners, levelers, or additives,
-- or any other chemicals if you suggest. Please help me.
plating - rajkot gujrat India
November 16, 2014
A. Hi Ritesh. Please see the applicable chapter of Volume 5 of the ASM Metals Handbook as suggested if you haven't yet, as well as Dennis & Such. And try the websites suggested by Marc Banks.
Brighteners aren't made by mixing generic chemicals; are you interested in the approach suggested by Asif Nurie and Anil Basrani of blending from intermediates furnished by others?
I'm not trying to give you a hard time, but designing brightener molecules and other additive molecules from scratch via organic synthesis from precursors is a difficult subject even for those of vast experience, which I don't have -- I wouldn't know how to begin :-)
Best of luck. Regards,
November 2014
