pub
Mustard Stripped the Copper Plating from Tart Pan
Q. Hello. My copper tart pan that hangs above my sink had some mustard shot up on it accidentally and since I was not the culprit -- I didn't see for a day or so. it completely took the finish down to the stainless in one spot.
copper plated tart pan kitchen knick-knacks
Any ideas on how to refurbish that? It's an aesthetic issue and not a functioning issue and was a good teaching moment with my 7 year old.
Kimberly Moreira
- Modesto, California
April 22, 2024
A. Hi Kimberly,
Unfortunately I don't think there is a great and easy solution. Doing spot plating on that is never going to work, and a plating shop would probably charge more to re-plate it than the replacement cost -- re-plating is doable if it is precious to you, but it's costly.
There are copper-tone metallic paints [on eBay or Amazon] that would it make the mark less obvious. Better than paint, if you want to try a new hobby, might be copper leafing the bare spot (same idea as gold leafing except with super-thin copper foil. I haven't done it myself but I believe you need the adhesive [on eBay or Amazon] , the copper leafing sheets [on eBay or Amazon] , and a special super soft brush to apply the leafing [on eBay or Amazon] . Sounds like fun if you have the time. If you are successful, a very light coat of lacquer would be good. If it's not as successful as you hope, then a little re-arranging so something is in front of the spot :-)
pic of Ted Mooney
