pub
Zinc plating with blue passivation is yellowish at holes
Q. Hi everyone, need help. My company does zinc plating with blue trichrome passivation. We are encountering yellowish issue at hole areas.
61615-1b   61615-1a
Information on our process:
Degrease
Electroclean
Rinse
Acid pickling
Predip( NaOH)
Zinc bath (alkaline non-cyanide)
Rinse
Bright dip
Rinse
Blue passivation (tri Cr)
Rinse x4
Hot water (70 °C)
Blow dry
Oven dry (60 °C) 10 min
We have tried
1) change blue passivation solution
2) change bright dip solution
3) change rinse water
All specifications follow supplier spec
I'm suspecting the hot water & oven drying temperature may cause this issue?
Can anyone help me on the root cause & troubleshooting
Thivaharan veeman
- Perak malaysia
November 29, 2023
A. Hi Thivaharan
While we await someone with actual experience with this particular problem, I would suspect inadequate agitation in the chromate tank, or rinsing which is either not quick enough or not thorough enough.
pic of Ted Mooney
A. I think you can try after zinc plate, 5-6 seconds 1% by vol. nitric acid dip, follow up rinses then go to trivalent blue dip.
popat patel
Popatbhai B. Patel
February 29, 2024
