Poor Adhesion of Nickel Plating on Neodymium
Q. Recently we are encountering flaking or peeling off of plating layer after conducting 250 °C x 10 mins (adhesion test).
Plating is only Nickel layer only. And the Nickel solution has no Brightener chemical. Will this be one of the reasons of such reject? Additionally, what other possible options to consider to address this issue.
Thank you in advance.
- Cavite Philippines
November 15, 2023
by Larry Durney
(currently UTL
on AbeBooks & eBay)
A. Hi JM,
There are many possible causes for poor nickel plating adhesion. I doubt that lack of brightener actually reduces adhesion, but highly stressed brittle plating can manifest/masquerade as poor adhesion.
But we need at least some general data or we're flailing in the dark. Is this barrel plating (make & break contact can cause it)? What is the substrate (stainless, aluminum, diecast, & leaded substrates require special pretreatment)? Have you successfully plated this exact part with this process before? Is there any possibility that silicones have found their way onto the parts (they're almost impossible to remove)? Is the adhesion problem exactly at the interface between substrate and plating (any flakes with only nickel both top & bottom)? Thanks.
Q. Good day Sir Ted.. thank you for replying immediately. - Cavite Philippines November 18, 2023 A. JM, consultant/chemist - Roseville November 22, 2023 |
A. Hi. The most conventional process for plating Nd magnets seems to be vacuum impregnation followed by Ni, Cu, and Ni again. But I don't have personal experience in plating on Nd. Sorry.
Q. Hi. Thank you for your reply.
I would like to respond and check your response.
The nickel layer adhesion problem
1) If adhesion between base metal and nickel layer-have cleaning problem.
Response : I rule out this one. Since if the cleaning has problem (or the pre-treatment process), flaking should also happen on Cu / Ni process.
2) nickel to nickel peel may be bipolar condition or transfer tank to tank too late or part dry.
Response : Flaking is happening between Ni and Substrate (or the material)
3) check the current problem.
Response : You mean Current (Ampere) setting? Currently set to 21A by 2 Hours.. actually I'm thinking the time of processing. But I don't have any study yet.
4) check anode (nickel metal in baskets) level too low
Response : If this is also the problem, we should also encountering flaking on Cu / Ni Process..
Im actually puzzled of what to do.. Currently we try to replace the solution yet not sure if this will help eliminate the flaking.
November 28, 2023
About/Contact - Privacy Policy - ©1995-2024 finishing.com, Pine Beach, New Jersey, USA - about "affil links"
