pub
Masking/Stop off for anodizing on complex parts
finishing.com is possible thanks to our supporting advertisers, including:
maskcoat banner
RFQ: Hello, We pretty regularly have complex aluminum parts with a lot of features (slots, threaded holes, bores, spot faces) that are chem filmed then anodized (either type 2 or type 3). We use a various methods to mask these products like silicone plugs and tape to cover pockets from lacquer stop off prior to dipping to help clean up then modified soldering irons with metal templates to achieve very clean and precise masking. Some features are very time consuming to plug like a series of small holes in a part that the customer wants protected from anodizing. I'm curious if anyone has found a liquid silicone product or similar that can be applied by hand, injected into these holes, trimmed once is dried, and easily removed after plating. I'm Also interested in any type of ground breaking stop off product. We are manufacturing very precise, geometrically complex parts, generally in low volume. Essentially any leaching or chemical entrapment could/will scrap these parts especially if the process is hard coat.
T Swope
- Winchester Kentucky
October 24, 2023
Our company, www.maskcoat.com, specializes in trying to help our customers with these problems. We can be reached at 1-888-218-7227 or email at info@maskcoat.com.
Jeremy
Jim Baldwin
Mask Coat LLC
West Monroe, Louisiana
maskcoat banner
January 24, 2024
