Reduce anodize thickness by leaving in tank with power off?
by Robert Probert
You'll love this book. Finishing.com has sold 880 copies over the years without ever a single return request :-)
Q. Type II Anodize of 7075 Aluminum. If the anodize is too thick is there a way to thin the coating safely without stripping?
I have been a chemical processor for 23 years and I am pretty sure you can leave unsealed aluminum in the sulfuric bath immediately after voltage is off for an extended time and the anodize will very slowly remove -- am I correct?
- Steelville Missouri
September 13, 2023
Ed. note: Welcome! Feel free to visit anonymously! But our 35-year legacy of warm aloha is incompatible with anonymity; please only post with your full real name.
A. Yes, it will be slowly removed if you do that...
But it will be also ruined, because the pore walls will erode in such a way as to leave the surface with a powdery "smut", which will be even more aggravated by subsequent sealing.
Sorry, there is no good way to partially "un-anodize" an anodized part's anodize thickness, short of stripping the coating and redoing it from the beginning.
- Czestochowa, Poland
September 14, 2023
