Decorative plating for classic zinc-clad desk?
Q. Have a client who wants to reproduce the zinc finish on some discontinued Restoration Hardware furniture. The finish is applied over thin brass (.020 or .025).
Scott Gross, Two Hills Studio
- Austin, Texas
March 29, 2023
A. Hi. I've personally never seen a plating shop produce anything that looks like that. My assumption is that the brass sheet pieces were zinc electroplated in a plating shop, or a roll of preplated brass sheet was produced on a continuous plating line, resulting in the conventional bright look of zinc plating ... then someone with artistic experience applied a blackening patina to produce this effect.
Thus I think sourcing it will require two steps, having a plating shop do the zinc plating, then having a bespoke artist convert the zinc to this appearance with a patina solution. You haven't introduced yourself yet, and you may well be the artist capable of producing this finish. I'm not sure if this was a technical question or a request for quotation.
Thanks. Have recommended .020" or .025" brass covered with Sculpt Nouveau's iron b metal coating.
I don't think it's plated bc the finish is easily scraped off.
- Austin, Texas
April 3, 2023
