How to detect whether powder coating is on GI vs CRCA?
Q. During assembly we found a mix-up issue. Please give a visual detection standard or is there any instrument for the same.
Abhijeet B. Berad- Maharashtra India
September 13, 2022
combo magnetic & eddy-current coating thickness tester
A. Hi Abhijeet. If there was a way to detect visually, buyers would insist on the process being improved so there wasn't :-)
A simple magnetic pull tester can reveal the combined thickness of non-magnetic galvanized and powder coated finishes, so if the galvanizing is quite thick and the powder coating is quite thin, perhaps it can differentiate. Beyond that you would need a more expensive non-destructive test such as x-ray fluorescence or beta backscatter.
