Random adhesion failure in Electrodeposition coating
Acronyms:
(hopefully helping readers more quickly understand the Q&A's)
PT = pretreatment (cleaning & phosphatizing)
ED = electrodeposition (electro-painting, electrocoating)
CED = cathodic electrodeposition (although the workpieces may be either cathodic or anodic in electrodeposition, these days almost all electrodeposition is CED)
Q. After ED process adhesion failure occurred randomly on parts? Best probable root cause knowing all PT and ED parameters within specified range.? Kindly share your best advice to know reason and eliminate the problem. PT, ED and oven parameters are okay and adhesion failure occurred randomly. Kindly share solution.
yogesh jadhav
- Ahemadabad Gujarat India
April 12, 2022
"Electrocoating: a Guidebook for Finishers"
by Electrocoat Association
"Electrocoats: Formulation and Technology"
by Bruggemann & Rach
April 2022
A. Hi yogesh. No finishing process can offer proper adhesion onto a surface with dirt or oil on it. So the first place to re-examine when random adhesion failures occur is the cleaning process. But you haven't yet told us the substrate, or offered any data or pictures -- and they will surely help.
pic of Ted Mooney
