Stains on 6061 Aluminum
April 6, 2022
Q. Hi
I'm Amer from Penang Malaysia.
We doing acid etch for Aluminum 6061.
Before performing polishing, there is a stain on the aluminum surface which only can be seen under UV light.
Anyone have experience facing this? What actually is the stain coming from? It's due to oxidization of the material?
It still cannot be removed after acid etch.
Appreciate your advice.
Amer ishak- Penang Malaysia
A. When you refer to an 'acid etch', what acid, or is it caustic? If you can, try nitric acid at 30-50%. Drew Nosti, CEF Anodize USA Ladson, South Carolina April 7, 2022 A. Hello Amer, supervisor - Cicero, Illinois Saporito Finishing Co. April 6, 2022 |
