How to prevent corrosion of dully powder coated CRCA panels from acid fumes?
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
Q. How can prevent corrosion in crca dully powder coated panels from acid fumes.
JEETENDRA MAKKAR- Faridabad/ Haryana/India
March 29, 2022
A. Hi JEETENDRA. An epoxy powder coating on top of proper zinc phosphatizing is probably the best you'll do with a sprayed thermosetting powder. May we assume UV-resistance is not required? Although nylon is not truly acid-resistant, a heavy fluidized-bed application of thermoplastic nylon should far well in mildly acidic situations.
If you need true acid resistance you probably would need plastisol coating.
March 2022
