Metallic Contaminants in Sulfuric Acid Anodizing Bath
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
Q. Does anyone know about the effects of metallic contamination in a type III sulfuric acid anodizing bath? We have been having a lot of trouble with the anodizing process recently. Analysis of the solution showed it contained copper, iron, zinc, and chromium. Does anyone know the acceptable limits for these in a sulfuric acid anodize bath? Does anyone know how this contamination affects the anodizing process? What type of artifacts will be visible in the anodized coating with respect to each of these elements? Any help or advice with this would be greatly appreciated.
Jessica Boike- Madison Alabama
July 19, 2021
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
or eBay or
A. Hi Jessica. Pinner says iron at above 50 mg/L and copper at above 125 mg/L are troublesome ... that's all I could quickly find.
This has the makings of a really interesting discussion but I don't think it's quite there yet :-)
What kind of "troubles" have you been having recently? What are the levels of "copper, iron, zinc, and chromium" that you are seeing? What "artifacts" are visible? Thanks.
July 2021
A. Be sure you take the titration sample during electrolysis. The copper plates out just as soon as the current is turned on, unless you have one of these new pulse or super imposed AC power supplies. In the case of a Boeing spec, the limits are set so low that it is impossible to anodize the first 777 engine cowling (2024) without exceeding the limit on copper, unless you take the analysis sample under electrolysis. Robert H Probert Robert H Probert Technical Services Garner, North Carolina July 21, 2021 Hi, - Madison Alabama July 21, 2021 |
A. To add to Ted's response, Brace published more restrictive limits than Pinner has. Brace says the following will lower brightness and corrosion resistance ...
Fe above 50 ppm.
Cu+Ni+Mn total combined above 50 ppm
Jon Barrows, MSF, EHSSC
GOAD Company
Independence, Missouri
July 26, 2021
